Date/Time: Fri, 22 Nov 2024 18:41:50 +0000
CANGE BAR COLOR IN SIERRA TREND
View Count: 2912
[2013-05-24 15:43:43] |
User59821 - Posts: 6 |
Hi-is there a way to change or at least darken the blue and red default colors in Sierra Trend indicator-thanks
[2013-05-24 17:11:03] |
M5amhan - Posts: 468 |
its a user contributed study, they didnt allow any colors to be changed. best i could figure out was change the draw style to "color bar hollow" then change the color of the candlesticks however you want through graphics settings |
[2013-05-24 17:57:41] |
Here is the source code for it: #include "sierrachart.h" //DEVELOPED BY TCAST //tcast@charter.net //SCDLLInit("SierraTrend"); /***********************************************************************/ SCSFExport scsf_SierraTrend(SCStudyGraphRef sc) { if(sc.SetDefaults) { sc.GraphName="SierraTREND"; sc.StudyDescription="SierraTREND. TTM trend replica by tcast. "; sc.Subgraph[0].Name="sierraTREND BAR"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_COLORBAR; sc.Subgraph[0].LineWidth = 3; sc.Input[0].Name = "Length"; sc.Input[0].SetInt(5); sc.Input[0].SetIntLimits(1, 1000); sc.FreeDLL = 0; sc.AutoLoop = 1; sc.GraphRegion = 0; return; } int i = sc.Index; int len = sc.Input[0].GetInt(); const DWORD upColor = RGB(0, 0, 255); const DWORD downColor = RGB(255, 0, 0); sc.Subgraph[0][i]=sc.BaseDataIn[SC_LAST][i]; if( sc.BaseData[SC_OPEN][i] >=sc.BaseData[SC_HIGH][i-len]) { sc.Subgraph[0].DataColor[sc.Index] =upColor ; } else if ( sc.BaseData[SC_OPEN][i] <=sc.BaseData[SC_LOW][i-len]) { sc.Subgraph[0].DataColor[sc.Index] = downColor; } else { sc.Subgraph[0].DataColor[sc.Index] = sc.Subgraph[0].DataColor[sc.Index-1]; } } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
