Date/Time: Sun, 22 Dec 2024 10:43:25 +0000
Trying to make a double vwap
View Count: 987
[2015-02-05 03:42:23] |
User48557 - Posts: 138 |
In the screen shot above i have 2 identical japan futures charts. The "Session Time" setting for each chart is set up differently as you can see. I also have the "volume weighted average price" study set up as default for each chart. The different "session times" for each chart is causing 2 different VWAP's to be drawn . My question is. Is there anyway i can have both of the vwaps that are currently showing on each chart . Both on one chart? When I go into the study settings for the "Volume weighted average price" I also tried to change that time at the bottom, but it has no effect. |
2 vwaps.GIF / V - Attached On 2015-02-05 03:29:23 UTC - Size: 366.29 KB - 387 views v wap settings.GIF / V - Attached On 2015-02-05 03:29:37 UTC - Size: 105.22 KB - 372 views |
[2015-02-05 04:19:01] |
Refer to help topic 28: https://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
