Date/Time: Sun, 22 Dec 2024 10:06:50 +0000
Random 0s in indicator
View Count: 863
[2015-02-04 19:00:43] |
CustomIndicators - Posts: 126 |
While building an indicator, I noticed that occasionally, but rarely, it will set a value at 0.00000000. When I hand calculate what that space should be, it turns out to be wrong. 0.00000000s would be insanely rare as it is. What could be causing the occasional skip? It happens, probably once out of every 5,000 calculations, but that could become detrimental later on in my trading. Its not based off 1 piece of data, its based on a small range of values that none of them are 0s.
[2015-02-04 21:16:30] |
We cannot help with this. We do not know what the context of this is all about. And the calculation result is what it is. Do what you need to to get the result that you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
