Date/Time: Sun, 22 Dec 2024 10:50:17 +0000
UNDO CHART DRAWINGS
View Count: 1060
[2015-02-04 15:24:30] |
User57072 - Posts: 49 |
I HAVE MANY CHART DRAWINGS ON A CHART. I MADE A DUPLICATE OF THIS CHART, AND ERASE ALL THE DRAWINGS ON IT. Whttp://www.sierrachart.com/image.php?l=1423063400412.png HEN I WENT BACK TO THE ORIGINAL CHART WITH ALL THE DRAWINGS, THE DRAWINGS ARE STILL THERE BUT THEY ARE CONFIGURED IN A WAY YOU CANT MAKE OUT WHAT IS WHAT. HOW DO I GET THE DRAWINGS IN THE ORIGINAL CHART BACK TO NORMAL ? |
[2015-02-04 16:58:15] |
Select Tools >> Pointer to prevent the numbers from being drawn on the Chart Drawings.
