Date/Time: Sun, 22 Dec 2024 10:47:11 +0000
Algorithm Reversal_Bar
View Count: 1080
[2015-02-04 02:34:34] |
2garin - Posts: 184 |
Good day support. Ask to check the algorithm for calculating the indicator Reversal_Bar. In the given example: Right chart MarketDelta (PNF 8 tic) left chart Sierra Chart (Reversal_Bar 8 tic). Vertices (shadow) candles are different. |
[2015-02-04 23:25:14] |
PTG - Posts: 57 |
I seem to remember that MD/IRT have this shadow on their PnF charts as per your screenshot. Not sure who has to check their algorithm based on that. |
[2015-02-05 04:01:20] |
How Reversal Bars work is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ReversalBar Make sure you also have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
