Date/Time: Sun, 22 Dec 2024 11:42:02 +0000
Size of trading dome
View Count: 835
[2015-02-03 15:41:45] |
tellerbe - Posts: 109 |
My trading dome is so large that the "center" button will not come on the screen. How do I reduce it's size? T.Ellerbee |
[2015-02-03 18:40:42] |
There is no button that says "center" on a Sierra Chart Trade DOM. Maybe you are referring to the TransAct program?
