Date/Time: Sun, 22 Dec 2024 11:13:41 +0000
ESTX50 index, with data feed interactive brokers(problem)
View Count: 1097
[2015-02-03 09:50:03] |
User50698 - Posts: 1 |
I can not do load index ESTX50, are connected with interactive brokers.non appears in the find simbol. there is a different way to load it or do I need a data feed different? thanks
[2015-02-03 17:26:07] |
This is the symbol format for that futures market: ESTX50-######-DTB Select File >> Find Symbol and select a specific contract under that symbol listed. Open a chart and if you still do not get a chart, provide the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
