Date/Time: Sun, 22 Dec 2024 11:21:20 +0000
Multiple Instruments on Single Chart
View Count: 1269
[2015-02-02 14:43:34] |
User46129 - Posts: 22 |
Is there a way to place multiple instruments into a chart, i.e., I would like to separately display ES, NISS and NVOL, each in their own window in a single chart. Thanks in advance.
[2015-02-02 17:41:09] |
Yes. Refer to this section here: Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
