Date/Time: Sun, 22 Dec 2024 11:28:52 +0000
Automatic Trendlines - Length input
View Count: 1079
[2015-02-02 05:25:15] |
motorola7 - Posts: 19 |
I want to draw a trendline connecting the Lows of the last 2 bars and redrawn on the completion of each new bar. For this I entered Length: 2, and New bars before auto adjustment: 1. Some of the lines look ok but then the Indicator changes the Length input to 5. Is this because it has to have a swing low (lower low, then higher low) before it will select a starting point? This would require more than 2 bars. Is there a Function that will just draw these simple lines (projected)? |
[2015-02-02 18:23:25] |
In the next release of Sierra Chart you will be able to use a Length of 2 with Automatic Trendlines. We do not see any problem with this.
