Date/Time: Fri, 11 Sep 2026 18:58:16 +0000
S&P Indices with SC real time exchange data feed
View Count: 1506
| [2015-02-02 05:04:36] |
| joshtrader - Posts: 568 |
So when I subscribe to S&P indexes, I can get $SRHC, $SRFI, $SRIN, $SRIT (health care, financials, industrials, technology). What about $SRCD, $SRCS, $SREN, $SRMA, $SRTS, $SRUT? (cons discretionary, cons staples, energy, materials, telecom, utilities)? The $IX~ indexes are basically identical and so they will work fine, but my question is more generally: are all the barchart S&P indexes not available in SC? And are all the symbols available in SC those that are shown in the "Find Symbol" box, or are there others which are available but not shown here? I do not see a biotechnology index, which would seem to be an essential component of any index offering, given the importance demonstrated in the industry in May 2014 to the broad market. I tried: $U7DB, $DSBT, $NBI, $SSPB, and none of those work. Date Time Of Last Edit: 2015-02-02 05:09:54
| [2015-02-02 18:06:24] |
Not all of the index symbols are listed but we can add them and we will add these: $SRCD, $SRCS, $SREN, $SRMA, $SRTS, $SRUT, $U7DB, $DSBT, $NBI, $SSPB, If you do not see a symbol listed it means we have to add it and you will not be able to access it otherwise. So let us know what other symbols you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-02 18:08:20
| [2015-02-06 17:30:15] |
Can you please add: $SLVI $SHBI Thank you! |
| [2015-02-06 18:09:12] |
We will add these.
| [2015-02-06 21:08:57] |
A quick question -- do I have to upgrade to a new SC release to see these new symbols, or are they done on your end so that old versions can use them too?
| [2015-02-06 22:07:27] |
You do not need to update. You only need to restart Sierra Chart.
| [2015-02-13 05:39:32] |
I tried to access $NBI, and I am getting daily bars but no intraday data, FYI.
Date Time Of Last Edit: 2015-02-13 05:40:59
| [2015-02-13 06:28:57] |
We will make sure this is added.
| [2015-02-13 06:34:11] |
Sorry for the additional message, but I checked a couple others in the list above ($SRCD, etc) and they also only have daily data, not intraday data, whereas all the ones in the built-in list in SC (from 'find symbol') do have intraday data already.
| [2015-02-14 02:29:24] |
This is now all done. Restart Sierra Chart to see the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-16 05:10:00] |
Still no intraday data for $SRTS, $SRCS, $SRMA, $SREN, $SRUT, $SLVI and $SHBI Started SC today, and get this error: HD Request # 108 | Downloading Intraday chart data for $SRTS to the file $SRTS.scid. Service: oec | 2015-02-16 00:07:11 Compressing file: C:\SierraChartOEC\Data\$SRTS.scid. This may take a while. | 2015-02-16 00:07:11 HD Request # 108 | Download start Date-Time: 2014-10-19 01:07:11.0 | 2015-02-16 00:07:11 HD Request # 108 | Error downloading historical Intraday data for $SRTS. FIX reject reason: Unknown contract | 2015-02-16 00:07:11 * HD Request # 108 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $SRTS | 2015-02-16 00:07:11 HD Request # 108 | Intraday download COMPLETE for $SRTS. Completion time: 0s. Unique request ID: 113 | 2015-02-16 00:07:11 Date Time Of Last Edit: 2015-02-16 08:01:31
| [2015-02-16 06:01:10] |
Not sure why these symbols are missing. We been doing some work on Symbol Settings. We will add these again.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-16 08:00:55
| [2015-02-16 07:16:08] |
Ditto this for $SLVI and $SHBI -- daily data but no intraday
