Date/Time: Sun, 22 Dec 2024 11:36:06 +0000
Sierra Chart Crash
View Count: 813
[2015-02-01 21:58:32] |
crazybears - Posts: 314 |
Hi sometime when i click on add custom studies, SC freezes . i tried to see if something appears on Message log but doesn't . on Windows messages WER , i see this: AppHangB1 attached are the WER files. maybe you can detect why it happens thanks. |
Private File Private File Private File |
[2015-02-01 23:52:35] |
Refer to help topic 17 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails17.html We do not need to see any of those files. You can delete the attachments. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-01 23:52:45
