Date/Time: Tue, 22 Sep 2026 04:05:39 +0000
data range is inaccurate
View Count: 1058
| [2015-01-31 18:05:53] |
| User80870 - Posts: 3 |
hi i was looking and previous data and it came to my attention that the S.C server’s data range only goes back until 2001 on certain pairs. how do i extend the range to see more historical data
| Attachment Deleted. |
| [2015-01-31 21:27:25] |
This means that is all the data that is available for that particular pair and chart data type. Add a ^ character in front of the symbol and you may be able to get data further back. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-31 21:27:35
