Date/Time: Sun, 13 Sep 2026 21:56:13 +0000
Wll Not Connect to Rithmic Data
View Count: 1505
[2015-01-31 15:36:26]
User59724 - Posts: 71
Last night I tried to log into SC, but it kept saying "Connecting . . . . Waiting to Reconnect" ad infinitum. I thought maybe Rithmic or SC data was doing some maintenance at 10:30 last night, but this morning the same problem. I need to get connected for some work I'm doing asap. Please help. Why won't my SC connect?
[2015-01-31 15:53:03]
Here's the log after reinstalling SC latest version:
Software version: 1224 | 2015-01-31 10:51:36
Uses New Spreadsheets | 2015-01-31 10:51:36
Usage end date: 2015-03-24 | 2015-01-31 10:51:36
Enabled for: Advanced Features. | 2015-01-31 10:51:36
Enabled for: Advanced Features 2. | 2015-01-31 10:51:36
Enabled for: Sierra Chart Historical Data Service. | 2015-01-31 10:51:36
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-01-31 10:51:36
Enabled for: DOW INDEXES exchange. | 2015-01-31 10:51:36
Enabled for: S&P INDEXES exchange. | 2015-01-31 10:51:36
Enabled for: NASDAQ INDEXES exchange. | 2015-01-31 10:51:36
Enabled for: NYSE INDEXES exchange. | 2015-01-31 10:51:36
Enabled for: RUSSELL INDEXES exchange. | 2015-01-31 10:51:36
Received 1 data feed usernames. | 2015-01-31 10:51:36
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-01-31 10:51:36
Active service: Rithmic Trading | 2015-01-31 10:51:36
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-01-31 10:51:36
2015-01-31 07:51:36 Local computer clock time | 2015-01-31 10:51:36
2015-01-31 15:51:36 GMT time | 2015-01-31 10:51:36
2015-01-31 10:51:36 Time zone adjusted time | 2015-01-31 10:51:36
Time difference to server time: 0 seconds. | 2015-01-31 10:51:36
Program path: C:\SierraChart\ | 2015-01-31 10:51:36
Data Files path: C:\SierraChart\Data\ | 2015-01-31 10:51:36
OS Version Number: 6.2 | 2015-01-31 10:51:36
Locale Information: C | 2015-01-31 10:51:36
Checking for new symbol settings for rim | 2015-01-31 10:51:36
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-01-31 10:51:36
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-01-31 10:51:36
Requesting symbol settings for rim. Overwrite = on. | 2015-01-31 10:51:37
Symbol settings received. | 2015-01-31 10:51:38
Processed received symbol settings | 2015-01-31 10:51:38
Rithmic Trading | Port for executable: 51277 | 2015-01-31 10:51:41
Listening socket (1796), port 51277 | Closed. | 2015-01-31 10:51:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-31 10:51:41
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-01-31 10:51:43
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-01-31 10:51:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51277 | 2015-01-31 10:51:43
Socket (2) | Connected. | 2015-01-31 10:51:43
Rithmic Trading | Connected to server. | 2015-01-31 10:51:43
Rithmic Trading | Sending logon request message. | 2015-01-31 10:51:43
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-31 10:51:43
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-31 10:51:43
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-31 10:51:43
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-31 10:51:45
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-01-31 10:51:45
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-31 10:51:45
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-31 10:51:45
Rithmic Trading | Logon error from server | 2015-01-31 10:51:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:51:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:51:45
Socket (2) | Shutdown and closed. | 2015-01-31 10:51:45
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:51:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:51:45
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:51:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51277 | 2015-01-31 10:51:49
Socket (3) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:51:50
Socket (3) | Shutdown and closed. | 2015-01-31 10:51:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:51:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:51:50
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:51:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:51:50
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:51:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51277 | 2015-01-31 10:51:54
Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:51:55
Socket (4) | Shutdown and closed. | 2015-01-31 10:51:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:51:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:51:55
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:51:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:51:55
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:51:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51277 | 2015-01-31 10:51:59
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:52:00
Socket (5) | Shutdown and closed. | 2015-01-31 10:52:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:52:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:52:00
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:52:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:52:00
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:52:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51277 | 2015-01-31 10:52:04
Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:52:05
Socket (6) | Shutdown and closed. | 2015-01-31 10:52:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:52:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:52:05
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:52:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:52:05
Rithmic Trading | Port for executable: 51292 | 2015-01-31 10:52:07
Listening socket (1796), port 51292 | Closed. | 2015-01-31 10:52:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-31 10:52:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51292 | 2015-01-31 10:52:09
Socket (7) | Connected. | 2015-01-31 10:52:09
Rithmic Trading | Connected to server. | 2015-01-31 10:52:09
Rithmic Trading | Sending logon request message. | 2015-01-31 10:52:09
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-31 10:52:09
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-31 10:52:09
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-31 10:52:09
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-31 10:52:10
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-01-31 10:52:10
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-31 10:52:10
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-31 10:52:10
Rithmic Trading | Logon error from server | 2015-01-31 10:52:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:52:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:52:10
Socket (7) | Shutdown and closed. | 2015-01-31 10:52:10
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:52:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:52:10
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:52:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51292 | 2015-01-31 10:52:14
Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:52:15
Socket (8) | Shutdown and closed. | 2015-01-31 10:52:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:52:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:52:15
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:52:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:52:15
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:52:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51292 | 2015-01-31 10:52:19
Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-31 10:52:21
Socket (9) | Shutdown and closed. | 2015-01-31 10:52:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-31 10:52:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-31 10:52:21
Rithmic Trading | Disconnected from the server. | 2015-01-31 10:52:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-31 10:52:21
Rithmic Trading | Bridge process is still running. | 2015-01-31 10:52:23
[2015-01-31 21:39:48]
You are receiving a "permission denied" error from Rithmic. Refer to step 17 here in the set up instructions Rithmic:
Rithmic Trading Platform Service: Setup Instructions
