Date/Time: Sun, 22 Dec 2024 16:14:59 +0000
Connection Issues
View Count: 791
[2015-01-31 14:26:11] |
User365472 - Posts: 1 |
Hi everyone, looking for some help. I have recently updated to version 1227 the pre-release one, as instructed for users of the OEC data service. But after logging on the heading shows I am in a SIM account, have checked the login details and they seem to be correct. Any ideas as to what I am doing wrong would be most helpful. Regards Lee B |
[2015-01-31 21:40:29] |
Refer to the instructions here to disable Trade Simulation Mode: https://www.sierrachart.com/index.php?page=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
