Date/Time: Sun, 22 Dec 2024 11:25:45 +0000
study price/overlay not working
View Count: 962
[2015-01-30 22:24:25] |
jivetrader - Posts: 410 |
when Color Background Based on Alert study from a higher-TF chart is set to Use Vertical Lines Instead of Coloring Bkgd (Yes), and this is overlayed onto a faster-TF chart, nothing appears. when Use Vertical is set to No, it appears fine. please advise as i need both functionalities. thanks.
[2015-01-30 23:10:53] |
Set the Draw Zeros input with the Study/Price Overlay study to Yes.
[2015-02-02 19:10:29] |
this has no effect. my settings are attached, please advise. |
study price overlay does not transfer vert lines.png / V - Attached On 2015-02-02 19:10:24 UTC - Size: 32 KB - 359 views |
