Date/Time: Sun, 22 Dec 2024 16:32:00 +0000
Chart Settings
View Count: 829
[2015-01-30 19:21:46]
User47638 - Posts: 35
I use Renko 10 tick charts to trade EUR/USD. I would like to see the correct currency value on P/L line in the Trade Window.
How to select Price display and tick size, currency value per tick and value per point in ticks on the chart settings menu?
[2015-01-30 19:52:35]
The Tick Size and Currency Value per Tick should already be set correctly for that symbol.
You can change the Position Profit/Loss format. This is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay
This help topic may also be helpful:
http://www.sierrachart.com/index.php?page=doc/helpdetails77.html
Date Time Of Last Edit: 2015-01-30 19:52:50
