Date/Time: Sun, 22 Dec 2024 16:36:41 +0000
Will there be a tool to migrate old spreadsheats to new one spreadsheats?
View Count: 835
[2015-01-30 17:11:05]
AndyL - Posts: 119
I have tested the new version, and it would be alot of work to get my old sheets working again. Do you plan on making the process less painful?
[2015-01-30 17:38:53]
When you open an old spreadsheet file, it will be converted to the new format but only the formulas and values are copied over.
We have had reports where this conversion process does not always work. When you open up the old spreadsheet file, is there an error given in the Message Log indicating a problem with the conversion?
Other than creating a new file in the new Spreadsheet format and copying over the formulas and values, there are no plans to do anything more than this.
Date Time Of Last Edit: 2015-01-30 17:39:52
