Date/Time: Sat, 03 Oct 2026 13:55:01 +0000
Chart order in chartbook
View Count: 1309
| [2015-01-30 02:10:46] |
| User726098 - Posts: 23 |
Hello, I currently have 5 charts in a chartbook, utilizing 2 charts on my screen at a time. I noticed that each chart has a number (#1,#2,#3...) on the top of the window. When I save the chartbook I want #1 and #3, to appear when initially opened, but it seems that it goes in sequence #1 & #2. Is there anyway to reorder the chart numbers without rebuilding it or at least saving the current layout upon exit? Thanks. |
| [2015-01-30 23:13:00] |
Update to the latest prerelease with Help >> Download Prerelease and let us know if you still see the problem. We fixed a problem with setting the active window in a Chartbook when it is opened and this may at least in part solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
