Date/Time: Sun, 22 Dec 2024 15:59:37 +0000
Emailed Questions
View Count: 909
[2015-01-30 02:07:18] |
Sierra Chart - Max - Posts: 5756 |
Is it possible in all the charts to set automatically support and resistance, at least the horizontal ones? He has having problem in opening the DOM, if he tries in the Settings he gets the message "your account type does not allow this feature". Is it because he is using a demo? Is it possible to see the volume as an histogram and not only as numbers? Sierra Chart Support Date Time Of Last Edit: 2015-01-30 02:15:54
[2015-01-30 02:17:43] |
1. Not sure what kind of support and resistance lines you require. But have a look at the Pivot Points study: http://www.sierrachart.com/index.php?page=doc/doc_PivotPoints.html 2. They will need a direct account: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html 3. The "Volume" study does appear as histogram/bars and not as numbers. Make sure you use the study named "Volume". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
