Date/Time: Sun, 22 Dec 2024 16:11:31 +0000
[User Discussion] - Volume By Price Value Area lines and other subgraphs
View Count: 1054
[2015-01-29 19:24:21]
User11527 - Posts: 10
For coloring the lines that limit the value area (so the high and low),
i need to use the subgraph "value Area and Outlines (SG17)" and the same
color is used for the high and low (extended) lines, and for the Outlines.
So, when will the subgraphs "Value Area High Value" (SG3) and "Value Area Low Value" (SG4)
be used ?
Date Time Of Last Edit: 2015-01-29 19:33:52
[2015-01-29 20:09:54]
We need to document these. These are not used for color control. They are used to contain the Value Area High and Low, so they can be viewed in the Chart Values windows or programmatically accessed by ACSIL.
