Date/Time: Sun, 22 Dec 2024 16:31:14 +0000
Number Bars Volume Filter
View Count: 2153
[2015-01-29 14:17:30] |
User71961 - Posts: 144 |
Can you add a Filter setting for the Number Bars Study, where only trades above a certain User Defined volume level are included / used for calculating the Number Bars? This filter, would essentially mean you would "ignore" any trade below a certain size. Also, this same filter setting would be great for the Cumulative DeltaBars - Volume study. Only including trades where the size is great then a user defined setting. It be great to be able to exclude, for example, all trades less than 50 contracts. All those small lots make it harder to see what the larger orders are doing. |
[2015-01-29 17:58:39] |
Here is the documentation for the volume filter: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VolumeFilterH Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
