Date/Time: Sun, 22 Dec 2024 16:25:54 +0000
lost files
View Count: 840
[2015-01-29 13:28:25] |
crow - Posts: 3 |
I inadvertently clicked on "clear recent files" instead of "open all chartbooks". When I saw they had been deleted I closed SC thinking I would get "save changes" but that didn't happen. Is there a way to recover my files? Thanks.
[2015-01-29 15:41:54] |
Sierra Chart - Max - Posts: 5756 |
If you have selected File >> Clear Recent Files List, then you only cleared the list but the files are still saved inside of your Sierra Chart Data Folder. To open the chartbooks select File >> Open Chartbook. After you open a chartbook it will be added to the above mentioned list. Sierra Chart Support Date Time Of Last Edit: 2015-01-29 15:42:14
