Date/Time: Sun, 22 Dec 2024 16:21:38 +0000
spreadsheet for trading
View Count: 934
[2015-01-29 00:48:19]
jimnovak - Posts: 42
hi
is it possible to use a spreadsheet to perform a very simple order placement task?
say price currently is 1.75 and i want to buy at 1.25. if i place a regular limit order, entry is made as soon as the price hits 1.25. now i dont want that. i want to buy at 1.25 only when the price has fallen below 1.25 and is on its way up and enter the trade then. i can currently do that with a buystop order but price has to be below 1.25 for it to work. i basically want to be able to set a trade as explained at prices higher than 1.25.
any help to put me in the right direction is appreciated.
attached is a link to a chart with an example scenario explained visually. http://www.sierrachart.com/image.php?l=14224920554.png
regards
[2015-01-29 02:26:05]
just to let you know that ive used crossfrombelow for this but it dont seem to work. so in column K(buy entry) i write
=crossfrombelow(E3,1.25) where 1.25 is a hard coded number. i understand this is pretty juvenile but was a try that not surprisingly didnt work. and same for exits.
[2015-01-29 13:58:10]
ive put the buy value in column P, and it fills it down i assume correctly. formula i use in column K is =CROSSFROMBELOW(E3:E4,P3:P4) now.
although initially seemed to trigger off correctly after a few more realistic tests, this doesnt seem to work either.
[2015-01-29 18:02:34]
Yes.
We do not provide automated trading system formula help or debugging. It is not within the scope of our support.
We can only refer you to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php
Date Time Of Last Edit: 2015-01-29 18:04:05
[2015-01-29 18:06:23]
It also sounds like you will need to use a stop order and you can control the order types through these cells:
http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#BuyEntryLimit
