Date/Time: Sun, 22 Dec 2024 15:52:43 +0000
backup charts to UBS thumb drive
View Count: 833
[2015-01-28 23:27:04] |
User91313 - Posts: 1 |
How do you backup and save charts to Thumb drive?
[2015-01-29 05:48:38] |
Refer to help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html You will need to copy the Sierra Chart Data Files Folder to the drive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
