Date/Time: Wed, 05 Feb 2025 10:45:20 +0000
Quote Board
View Count: 1607
[2013-05-23 20:48:54] |
guyl - Posts: 58 |
I was wondering if anyone has a clue as to what the "net change" tab in the quote board is calculating? I have no idea what mine is calculating but what it should be calculating is the change from yesterday's closing price to the price today and the "net change %" should reflect that change on a percentage basis. Is there a formula that I can correct/adjust to get it right? That number is also showing up on my charts on the very top line as the second number after the price and listed as "DChg". The first number after the price is listed as "Chg" and that is the correct number as to the daily change and that number is the one that should be showing up on the quote board. Thank you very much and let me know if this is not clear to you. |
[2013-05-23 23:12:08] |
Your understanding of what it should be calculating is correct. Whether it is correct or not, depends upon the particular Data or Trading service you are using. What service are you using? You also need to be aware that the Net Change uses the official settlement close which is different than the last trade price of the day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-23 23:21:25] |
guyl - Posts: 58 |
I'm not sure what you mean by trading service but I'm using charts provided by Infinity Futures - they call them AT charts. Is that what you are looking for?
[2013-05-23 23:40:02] |
OK please contact your Trading service (Infinity Futures) about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-23 23:40:26
