Date/Time: Sun, 22 Dec 2024 15:46:27 +0000
Chart DOM no Market Depth
View Count: 1998
[2015-01-27 08:28:01] |
User51760 - Posts: 108 |
Hello Support Team, on Sierra Chart Real-Time and Historical Exchange Data Feed I receive volume data in the T&S Window - but I cannot see the depth of market in the DOM. I wonder what setting I might have changed unintentionally - probably I need to activate an option somewhere. Please point me into the right direction. Best, Chris |
sc_no_depthofmarket.png / V - Attached On 2015-01-27 08:27:29 UTC - Size: 30.67 KB - 461 views |
[2015-01-27 09:08:59] |
Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns You need to add the Bid and Ask Size fields. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-27 10:17:20] |
Thank you for your fast answer. I am sorry for some confusion concerning terms: what I referred to was the Trade DOM, not Chart DOM. Anyway: the question remains the same: Until recently I was able seeing the depth of market numbers inside the Buy/Sell Order Column (please refer to the attached .png). Did you change anything? Is it possible to change back to adding the depth of market numbers inside the Buy/Sell Order Column since I do not want two more columns in my Trade DOM. Thank you for your consideration. |
sc_depthofmarket_inside_buysellcolumn.png / V - Attached On 2015-01-27 10:15:13 UTC - Size: 56.41 KB - 470 views |
[2015-01-27 16:43:12] |
The documentation in this section: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns (Customizing Trade DOM and Chart DOM Columns) Applies to both the Chart DOM and Trade DOM. You need to add these columns: Bid Size/Buy Column Ask Size/Sell Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
