Date/Time: Sun, 22 Dec 2024 15:47:43 +0000
Measured move tool., how to
View Count: 2047
[2015-01-26 21:23:28] |
Willson - Posts: 176 |
What is method or tools to draw a line between price points ( for example a swing low point ) on a chart which then displays the line, Points or ticks (using text) and maybe an arrowhead,.. Then to identify a similar move, the tool can be reused to start at a different swing point and indicates the second swing range with text of points or ticks. Regards |
[2015-01-27 19:00:28] |
You can do this with the Chart Calculator drawing tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-27 19:01:58
