Date/Time: Sun, 22 Dec 2024 15:42:37 +0000
Multiple instances of SierraChart
View Count: 888
[2015-01-26 18:17:16] |
User72411 - Posts: 3 |
Hi, need help with running of multuple instances of this software. I need it for 2 monitors. It must be running simulataneously. Normally clicking on the icon of this software just reopens alredy running application and do not open second instance of SC. Thank you in advance Regards S. |
[2015-01-26 23:14:59] |
Here is the information to run multiple copies of Sierra Chart: Using Multiple Data and Trading Services at the Same Time However, you may just want to detach charts and use a single copy of Sierra Chart. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
