Date/Time: Sun, 22 Dec 2024 15:41:43 +0000
change a stop on the chart without confirmations
View Count: 1072
[2015-01-26 14:20:31] |
User52247 - Posts: 26 |
Hi, How to change a stop on the chart without confirmations (I didn’t find it). Thank you for your answer ad101166 |
[2015-01-26 17:10:47] |
Here are the instructions to disable confirmations: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-26 18:31:12] |
My problem is not resolved because I have removed all confirmations, but all mofications require confirmations.(see attached graphs) : http://cjoint.com/?EAAtOhsVo2C Date Time Of Last Edit: 2015-01-26 18:32:47
Sierra graphe.JPG / V - Attached On 2015-01-26 18:28:32 UTC - Size: 139.94 KB - 362 views |
[2015-01-26 19:22:27] |
Each chart and Trade DOM has its own Trade Window. So go to the particular chart you want to trade from and select Trade >> Open Trade Window for Chart and disable the confirmations.
