Date/Time: Sun, 22 Dec 2024 16:14:36 +0000
Orders on additional SC Instances
View Count: 866
[2015-01-26 09:54:35] |
User78442 - Posts: 260 |
I tried to place an order on a 3rd instance of SC for IMAX with the primary instance being OEC. How can I place the Order via IMAX? It was rejected as it was referring back to OEC. Obviously something is wrong? I tried to reference IMAX in the Trade and Current Quote Symbol Box but you can only include OEC. Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22889. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:10:35 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22890. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:10:35 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22891. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22892. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22893. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22894. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22895. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * Trade Order Error - OEC order update (Rejected). Text: MaturityMonthYear not specified.. Internal Order ID: 22896. Service Order ID: (none). Symbol: EURAUD | 2015-01-26 09:51:43 * |
[2015-01-26 10:02:44] |
What you want to is not supported.
[2015-01-26 10:29:18] |
I'm assuming that I need to go to the instance that IMAX is running on and place orders via that? If that's the case is there an easy way to set-up different instances of SC with the same profile (Core settings on graphics etc.)?
[2015-01-26 16:47:33] |
I think I have a solution - Closed..
[2015-01-26 17:25:36] |
Yes, the orders must be placed from the LMAX instance of Sierra Chart. Refer to help topic 15 for the other question: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
