Date/Time: Sat, 19 Sep 2026 20:30:18 +0000
No historical daily data from e-mini ES,NQ,YM
View Count: 1416
| [2015-01-25 19:08:06] |
| User86536 - Posts: 3 |
Hello, I have put the symbol f.e. NQ.dly to diplay but I get different data, different chart. What am I doing wrong? Can you please tell me the steps to display any historical daily data for e-mini. Subscribed package service 3 Thank you |
| [2015-01-25 19:41:00] |
That is not the correct symbol since there is no month and year code on it. Locate the correct symbol through File >> Find Symbol. Each of these symbols you want Historical Daily charts for are listed there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-26 05:43:23
| [2015-01-26 20:49:19] |
OK. I added year and month (f.e.NQH15) but still I am not able to get Historical data 10year +. Only 24-36 months. Can someone state some example to get e-mini 10year +. Thank you |
| [2015-01-26 21:05:13] |
Follow the instructions on this page: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
