Date/Time: Sun, 22 Dec 2024 03:24:02 +0000
[User Discussion] - reversal bar
View Count: 1485
[2015-01-25 18:01:55] |
david koresh - Posts: 6 |
Hello there I wanted to know if there is a possibility you update the possibility of a reversal bar For example, only if the direction is 6 tick So if he returns 3 tick then opened a new bar It would be possible to set example (6,3) (8,4) any number I want I have a DLL that works this way but Paul Beck does not work with him I'd love to get an answer as soon as possible I've included you dll file and cpp |
OFARealChart.dll - Attached On 2015-01-25 17:59:51 UTC - Size: 89 KB - 455 views OFARealChart.cpp - Attached On 2015-01-25 17:59:57 UTC - Size: 8.06 KB - 437 views |
[2015-01-26 07:57:41] |
This is not likely something that we would be adding unless there is a lot of requests for it.
[2015-04-16 12:09:42] |
jwick - Posts: 142 |
I'd be interested in this as well. lol However, looks like not many others so far ;)
