Date/Time: Sun, 22 Dec 2024 16:52:55 +0000
[User Discussion] - Study behavior change after running AutoTrade System Based Bar Backtest
View Count: 960
[2015-01-25 17:19:23]
User85417 - Posts: 3
There a study I wrote (began with user contributed source code) that plots the previous day high, low, and close. The study is working correctly on the chart. However after running the AutoTrade System Based Bar Backtest the high and low plots change to plot the high and low of the beginning bar of the new day. THe close plot does not change. Running Chart Recalculate, the high and low plots are fixed. I want to use this code in a strategy and backtest it, but running the backtest breaks the code.
I'm thinking that a possible fix would involve a new array that stores the high and low. However, those who are more familiar with SC backtesting might have a better fix. Also, I'm curious about how the backtesting is changing the behavior.
Screenshot images below. The first image is of the study plots before the backtest was run. Plots are of the previous day: Red = High, Orange = Close, Green = Low
http://www.sierrachart.com/image.php?l=142220467574.png
http://www.sierrachart.com/image.php?l=1422204753412.png
SCSFExport scsf_ORTradeSignal(SCStudyGraphRef sc)
int sc_index = 0;
SCSubgraphRef Output1 = sc.Subgraph[sc_index++];
SCSubgraphRef Output2 = sc.Subgraph[sc_index++];
SCSubgraphRef Output3 = sc.Subgraph[sc_index++];
// Declare Inputs
int InputIndex = 0;
SCInputRef DistanceFromCandle = sc.Input[InputIndex++];
  if (sc.SetDefaults)
   sc.GraphName="OR Trade Signal";
   sc.StudyDescription="Opening Range Trade Signals";
// Default Input Settings
DistanceFromCandle.Name = "DistanceOfSignalFromBar";
   DistanceFromCandle.SetInt(1);
// Default Output Settings
Output1.Name="Close";
Output1.DrawStyle = DRAWSTYLE_DASH;
Output1.PrimaryColor = RGB(255,128,0);
Output2.Name="High";
Output2.DrawStyle = DRAWSTYLE_DASH;
Output2.PrimaryColor = RGB(255,0,0);
Output3.Name="Low";
Output3.DrawStyle = DRAWSTYLE_DASH;
Output3.PrimaryColor = RGB(0,255,0);
sc.ScaleRangeType = SCALE_SAMEASREGION;
    sc.GraphRegion = 0;
sc.AutoLoop = 0; //0 for manual looping
sc.FreeDLL = FREEDLL;
    sc.DrawZeros=0;
return;
   * Create Sub-Graph outputs
  float& High   = sc.PersistVars->f1;
float& Low     = sc.PersistVars->f2;
  float& DailyHigh = sc.PersistVars->f3;
float& DailyLow   = sc.PersistVars->f4;
float& Close = sc.PersistVars->f5;
float& DailyClose  = sc.PersistVars->f6;
  int& iDstart  = sc.PersistVars->i1;
int plot_offset = DistanceFromCandle.GetInt();
int i,j;
if (sc.UpdateStartIndex == 0)
iDstart=0;
High = sc.BaseDataIn[SC_HIGH][0];
Low = sc.BaseDataIn[SC_LOW][0];
// Manual looping, therefore all processing is done in this for loop
//loop for all bars starting at the farthest back in time
  for (i = sc.UpdateStartIndex; i < sc.ArraySize; i++)
    int p = i-1, BarDoW, PreviousBarDoW;
    BarDoW = sc.BaseDateTimeIn[i].GetDayOfWeek(); //get this bar's DoW
PreviousBarDoW = sc.BaseDateTimeIn[p].GetDayOfWeek(); //get previous' DoW
// DayOfWeekEnum SUNDAY = 0, MONDAY = 1, TUESDAY = 2, WEDNESDAY = 3,
// THURSDAY = 4, FRIDAY = 5, SATURDAY = 6
    if(BarDoW != PreviousBarDoW) // new day
DailyHigh = High;
DailyLow = Low;
      High = sc.BaseDataIn[SC_HIGH][i];
Low = sc.BaseDataIn[SC_LOW][i];
DailyClose = Close;
//Get the HL for the first minute
FirstMinHigh = sc.BaseDataIn[SC_HIGH][i] + 0.75;
FirstMinLow = sc.BaseDataIn[SC_LOW][i] - 0.75;
else //update the HLC for the day
Close = sc.BaseDataIn[SC_LAST][i];
if(sc.BaseDataIn[SC_HIGH][i] > High) High = sc.BaseDataIn[SC_HIGH][i];
      if(sc.BaseDataIn[SC_LOW][i] < Low) Low = sc.BaseDataIn[SC_LOW][i];
    //Display outputs
Output1[i] = DailyClose;
Output2[i] = DailyHigh;
Output3[i] = DailyLow;
[2015-01-25 19:08:51]
What you are describing is a bug with the study you are using.
Use the Sierra Chart Daily OHLC study to get the data you need and reference the data by following the method described here:
http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#UsingStudyData
