Date/Time: Sun, 22 Dec 2024 16:01:00 +0000
Crosshairs on detatched charts
View Count: 788
[2015-01-25 16:21:14] |
ripsdips - Posts: 143 |
Is there a way to have crosshairs tool to be displayed simultaneously on a multi display detached chart workspace?
[2015-01-26 17:07:52] |
Yes. Use the Global Cursor: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
