Date/Time: Sun, 22 Dec 2024 15:56:59 +0000
Cant connect to my OEC data feed
View Count: 931
[2015-01-24 18:55:30]
User319694 - Posts: 1
Any one can please help
this the message i get
Software version: 1224 | 2015-01-24 10:54:16
Uses New Spreadsheets | 2015-01-24 10:54:16
Usage end date: 2015-02-21 | 2015-01-24 10:54:16
Enabled for: Advanced Features. | 2015-01-24 10:54:16
Enabled for: Sierra Chart Historical Data Service. | 2015-01-24 10:54:16
Allow Support for Sierra Chart Data Feeds is disabled. | 2015-01-24 10:54:16
Active service: Open E Cry FIX | 2015-01-24 10:54:16
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-01-24 10:54:16
2015-01-24 10:54:16 Local computer clock time | 2015-01-24 10:54:16
2015-01-24 18:54:16 GMT time | 2015-01-24 10:54:16
2015-01-24 10:54:16 Time zone adjusted time | 2015-01-24 10:54:16
Time difference to server time: 1 seconds. | 2015-01-24 10:54:16
Program path: C:\SierraChart\ | 2015-01-24 10:54:16
Data Files path: C:\SierraChart\Data\ | 2015-01-24 10:54:16
OS Version Number: 6.1 | 2015-01-24 10:54:16
Locale Information: C | 2015-01-24 10:54:16
Checking for new symbol settings for oec | 2015-01-24 10:54:16
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-01-24 10:54:16
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-01-24 10:54:17
Requesting symbol settings for oec. Overwrite = on. | 2015-01-24 10:54:17
Symbol settings received. | 2015-01-24 10:54:18
Processed received symbol settings | 2015-01-24 10:54:19
Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-01-24 10:54:22
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-01-24 10:54:22
OEC FIX Trading socket (2) | Connected. | 2015-01-24 10:54:22
OEC FIX Trading socket (2) | Starting SSL connection. | 2015-01-24 10:54:22
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-01-24 10:54:23
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-01-24 10:54:23
OEC FIX Trading socket (2) | SSL connection established. | 2015-01-24 10:54:23
OEC FIX Trading: Sending the Logon message. | 2015-01-24 10:54:23
OEC FIX Trading: Received a Logout message. | 2015-01-24 10:54:23
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-01-24 10:54:23
OEC FIX Trading socket (2) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-24 10:54:23
OEC FIX Trading socket (2) | SSL has been shut down. | 2015-01-24 10:54:23
OEC FIX Trading socket (2) | SSL object has been freed. SSL state is now disconnected. | 2015-01-24 10:54:23
OEC FIX Trading socket (2) | Shutdown and closed. | 2015-01-24 10:54:23
OEC FIX Trading: Logged out and disconnected. | 2015-01-24 10:54:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-24 10:54:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-24 10:54:23
OEC FIX Trading: DisconnectFIX called. | 2015-01-24 10:54:23
Disconnected from Open E Cry. | 2015-01-24 10:54:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-24 10:54:23
Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-01-24 10:54:26
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-01-24 10:54:26
OEC FIX Trading socket (3) | Connected. | 2015-01-24 10:54:26
OEC FIX Trading socket (3) | Starting SSL connection. | 2015-01-24 10:54:26
OEC FIX Trading socket (3) | SSL connection established. | 2015-01-24 10:54:27
OEC FIX Trading: Sending the Logon message. | 2015-01-24 10:54:27
OEC FIX Trading: Received a Logout message. | 2015-01-24 10:54:27
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-01-24 10:54:27
OEC FIX Trading socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-24 10:54:27
OEC FIX Trading socket (3) | SSL has been shut down. | 2015-01-24 10:54:27
OEC FIX Trading socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-01-24 10:54:27
OEC FIX Trading socket (3) | Shutdown and closed. | 2015-01-24 10:54:27
OEC FIX Trading: Logged out and disconnected. | 2015-01-24 10:54:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-24 10:54:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-24 10:54:27
OEC FIX Trading: DisconnectFIX called. | 2015-01-24 10:54:27
Disconnected from Open E Cry. | 2015-01-24 10:54:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-24 10:54:27
Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-01-24 10:54:30
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | Connected. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | Starting SSL connection. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | SSL connection established. | 2015-01-24 10:54:30
OEC FIX Trading: Sending the Logon message. | 2015-01-24 10:54:30
OEC FIX Trading: Received a Logout message. | 2015-01-24 10:54:30
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | SSL has been shut down. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-01-24 10:54:30
OEC FIX Trading socket (4) | Shutdown and closed. | 2015-01-24 10:54:30
OEC FIX Trading: Logged out and disconnected. | 2015-01-24 10:54:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-24 10:54:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-24 10:54:30
[2015-01-24 20:34:25]
Refer to this section here:
https://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem
Date Time Of Last Edit: 2015-01-24 20:35:01
