Date/Time: Sun, 22 Dec 2024 16:47:24 +0000
study overlay with different timeframes
View Count: 1596
[2015-01-23 17:48:48] |
User28696 - Posts: 7 |
Hi, When i use a study overlay, the study does not show on the actual bar, it waits for the bar to close to update. I want the overlay to update live if it changes in the faster timeframe that it is in. To resume, If the study changes, I want it to change on any other chart at the same time. thanks |
[2015-01-24 20:55:41] |
Refer to the documentation for the Inputs for that study. http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s118 Adjusting one of them will solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
