Date/Time: Thu, 17 Sep 2026 08:15:21 +0000
Cumulative Delta Bars - Volume
View Count: 1445
[2015-01-23 17:24:01]
User28682 - Posts: 233
Cumulative Delta Bars - Volume is the cumulative sum, over the data in the chart or the trading day, of the difference between the Ask Volume and the Bid Volume, displayed as High-Low CandleStick bars.
Does this assume all volume is accounted for?, so when the spread between the bid/ask allows a trade in between, that volume is assigned a +/- based on the trade being an uptick or downtick?
Any instances where some volume is NOT assigned a +/-?
Overall, if your global setting is set to "Ticks" is this study accurate if I am using SC as my data provider?
Tom
[2015-01-23 17:39:43]
Yes.
No.
Yes.
