Date/Time: Sat, 12 Sep 2026 16:08:04 +0000
Trend Lines
View Count: 1400
| [2015-01-23 16:58:55] |
| gmorgan111 - Posts: 121 |
The angle that is shown on the top bar is not accurate. That is why i was asking how to draw a trend line on an angle that is accurate. Also why do my trend line angles change as more bars are plotted on my chart from left to right. Also any figure i draw like an ellipse or rectangle also grow in size as more candles are plotted on my charts Thanks |
| [2015-01-24 01:25:11] |
Refer to the documentation here for this: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Angle That section should answer your questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
