Date/Time: Sun, 22 Dec 2024 16:29:30 +0000
Trend Lines
View Count: 889
[2015-01-23 16:45:44] |
gmorgan111 - Posts: 121 |
Is there a way to draw a trend line on a specific angle Thanks |
[2015-01-24 01:25:28] |
Refer to the documentation here for this: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Angle That section should answer your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
