Date/Time: Sun, 22 Dec 2024 16:28:15 +0000
Replay resolution ?
View Count: 1145
[2015-01-23 13:50:06] |
User120827 - Posts: 77 |
Hi Can you tell me the resolution of accurate replay ? Is it tick based resolution ? second ? minute ? thanks shane |
[2015-01-24 01:17:31] |
This depends upon the data in the Intraday chart data file. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
