Date/Time: Sun, 22 Dec 2024 16:46:09 +0000
LMAX: Bid-Ask is same!
View Count: 871
[2015-01-23 11:38:48] |
Entropy - Posts: 36 |
On the LMAX Web Trader platform the bid-ask is different as it should be. When I today updated to SC 1225, bid and ask is exactly the same! Please check what's wrong. Cheers |
[2015-01-23 16:51:14] |
This problem has been confirmed and it will be corrected with the next release coming out later today.
