Date/Time: Mon, 28 Sep 2026 10:09:18 +0000
LMAX: EXPOSURE_CHECK_FAILURE
View Count: 2114
[2015-01-23 11:18:57]
galmasi80 - Posts: 2
Dear Support!
I'm using the following code-snippet to make a buy order:
double price = some_func_here();
s_SCNewOrder main_order;
main_order.OrderType = SCT_ORDERTYPE_LIMIT;
main_order.TimeInForce = SCT_TIF_GTC;
main_order.OrderQuantity = 600;
main_order.Price1 = price;
main_order.TextTag = "Main order (position open)";
int r = sc.BuyEntry(main_order);
The call to BuyEntry succeeds, however in the Trade Service Log, sometimes I get the following message:
Trade Order Error - LMAX order update (Rejected). Info: EXPOSURE_CHECK_FAILURE. Internal Order ID: 6287. Service Order ID: (none). Symbol: GBPUSD
What's the meaning of the error message "EXPOSURE_CHECK_FAILURE"?
Best regards.
[2015-01-23 11:31:30]
This is from LMAX:
[2015-01-23 12:00:25]
Hi Support,
Yes, it is clear that the error message comes from LMAX.
Do I fill the s_SCNewOrder structure correctly?
What's the description of the EXPOSURE_CHECK_FAILURE message? (Because it is only a symbolic name, which doesn't say so much about the error reason).
Best regards.
[2015-01-23 17:00:03]
Yes, you did fill in the s_SCNewOrder structure correctly.
We do not know the descriptive name of that error message text from LMAX. You need to ask LMAX what that means when it is received in a Text field of a FIX Execution report.
Date Time Of Last Edit: 2015-01-23 17:00:21
[2015-01-24 00:46:30]
AndyL - Posts: 119
Most likely wrong orderquantity. Fix uses absolute amounts (10000 for a minilot). Just try different amounts(i would start with 1000 and 1) on demo and look at the result on the webplatform.
Date Time Of Last Edit: 2015-01-24 00:47:05
[2015-01-24 01:09:45]
We do not think it is a quantity problem. But it might be a risk management error.
In Sierra Chart 10 equals a standard LMAX lot size.
