Date/Time: Sun, 22 Dec 2024 16:30:48 +0000
no tick data + no find symbol
View Count: 832
[2015-01-23 00:23:47]
onnb - Posts: 662
hi - a new account is opened in trial period, have the storage unit set to 1-tick. Opening a 1 tick chart and seeing 1 min data (i.e., not getting tick data).
On latest build with old spreadsheets
Using "SC Historical Data"
Also, when I go to "Find Symbol", list is empty
Any ideas?
[2015-01-24 01:26:21]
Update the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings
This will solve the problem.
After getting the symbol settings, go back to the chart and select Edit >>Delete All Data and Download.
