Date/Time: Sun, 22 Dec 2024 15:35:21 +0000
Jump to Front Chart When Chart is Selected
View Count: 899
[2015-01-22 15:09:01] |
infpz - Posts: 826 |
Is this global setting available?
[2015-01-22 18:05:24] |
No, but you can use this menu command: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#GotoEndofChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
