Date/Time: Sun, 22 Dec 2024 15:05:51 +0000
Really stupid question about Assigining alerts
View Count: 845
[2015-01-22 13:55:12] |
mogull - Posts: 40 |
For the record I am on version 1168, After exhausting efforts thtough support, my settings don't work in I upgrade and someone in support told me to just keep the older version if it works. Here is the question. In my memory when I click "global settings> general settings" in the box it had a pulldown in the box that was for alerts. You pulled down to a particular alert and then put in the alert sound you wanted to assign to that alert number, I can't find that pulldown. And as you can see I didn't upgrade to a new version that got rid of it. I am feeling rather stupid. Where is the pulldown to assign alerts? Thanks Alan |
[2015-01-22 16:53:03] |
Sierra Chart - Max - Posts: 5756 |
In version 1168, you can find the Alert Settings under: Global Settings >> General Settings >> General 3 Note that General 3 is a tab on the General Settings dialog. Sierra Chart Support |
