Date/Time: Sun, 22 Dec 2024 15:25:37 +0000
Trade from second SC
View Count: 856
[2015-01-22 10:52:03] |
Trade Nice - Posts: 75 |
To spread processing power, a second instance of SC can be set up to access the data from another instance of SC which is the one connected to the data supplier. But for example, if the first instance is connected to the FXCM Trade connection, is it possible to trade via charts on the second instance, but through the first instance, so only needing one FIX connection effectively shared between two instances of SC, each of which can therefore be used to trade from charts? |
[2015-01-23 09:51:41] |
No. This is not supported. This may be supported later on.
[2015-01-26 22:36:25] |
if the first instance is connected to the FXCM Trade connection, is it possible to trade via charts on the second instance, but through the first instance, so only needing one FIX connection effectively shared between two instances of SC, each of which can therefore be used to trade from charts? No. This is not supported at this time. You can only trade from the instance connected to the trading service.
