Date/Time: Sun, 22 Dec 2024 19:31:16 +0000
Linking
View Count: 1072
[2015-01-22 04:31:26]
guyl - Posts: 58
I am trying to link some charts. I know how to link, I just don't know whether I can link this way. I have 4 charts showing on my monitors. I want all 4 linked so when I change symbols they all change. Then I want to be able to also change time frames but I only want 3 of the charts to change. In other words, I want one chart to stay on a weekly time frame but I want to be able to change the other 3 to daily or hourly or whatever but when I want to change symbols I want all 4 to change to the same symbol. Can I do this?
[2015-01-23 07:18:33]
This is being reviewed and we are going to be enhancing the chart linking options in the next few weeks to support what you want as well as other things.
[2015-02-01 19:58:40]
guyl - Posts: 58
How will I be notified when the changes are made?
[2015-02-05 04:28:15]
You need to check the What Is New Page periodically:
https://www.sierrachart.com/index.php?page=doc/new.html
[2015-03-17 17:22:25]
guyl - Posts: 58
It looks like you made some kind of change to linking recently but it doesn't appear you did what I was looking for.
I found a "session times" under the "type" tab under "linking". Was this added? When I use this all the charts change as I toggle between time frames. Like I mentioned above, I want 1 chart to stay on weekly and the other 3 to change as I change time frames.
[2015-03-19 21:37:37]
guyl - Posts: 58
Bump
[2015-03-24 13:57:08]
guyl - Posts: 58
Bump
[2015-03-30 03:03:20]
guyl - Posts: 58
I suppose if I keep bumping this EVENTUALLY someone will answer!
[2015-03-31 22:40:49]
We need to do some additional work on this linking feature and then update the documentation. We will try to get this done today.
[2015-05-26 10:23:22]
guyl - Posts: 58
Please re-read my question/request and tell me if your release 1245 addresses this? If it does would you tell me how to do it as I still can't make it work.
[2015-05-26 13:11:54]
Update to the latest release of Sierra Chart. This is supported.
How Chart Linking currently works is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber
