Date/Time: Thu, 26 Dec 2024 17:48:50 +0000
[User Discussion] - Sock Renko not working, how to get Renko chart with ATR based size
View Count: 1531
[2015-01-21 16:36:57] |
User44804 - Posts: 7 |
Hi, do you have a possibility to create Renko charts which adapt the box size to a multiple of the ATR study? The Sock Renko Study seems to have this function, but it isn't working. Thank you in advance |
[2015-12-16 02:35:41] |
User959740 - Posts: 1 |
Old post but no response and I cant find an answer. SC can this be done?
[2015-12-16 06:25:53] |
This is not supported in Sierra Chart.
