Date/Time: Sun, 09 Feb 2025 03:25:33 +0000
shortcuts FLATTEN
View Count: 1650
[2015-01-21 10:16:19]
User68117 - Posts: 67
I have a request regarding shortcuts FLATTEN command.
I'm allowed in GLOBAL SETTINGS / SETTINGS CHART TRADE down in WINDOW TRADE CONTROLS all 6 check.
I also have for each graph in TRADE checked TRADING KEYBOARD SHORTCUT ENABLED.
I have assigned a keyboard shortcut for the command FLATTEN.
Yet shortcut does not work.
Where can please a mistake?
Thank you.
[2015-01-21 21:47:34]
We are not seeing this problem in testing and it may have been already resolved in an upcoming release we will have out in another day or two.
Update to prerelease version 1225 in about one or two days.
[2015-01-21 23:49:38]
User77270 - Posts: 23
Do other shortcuts work? Sometime the problem is that the windows is not focused. Click on the chart before pressing the shortcut - maybe the helps.
[2015-01-22 00:29:59]
This should all be fixed in the next release. The chart does need to be active for chart related keyboard shortcuts to work.
[2015-02-05 14:09:25]
I need to set "CTRL ALT Q", but it does not work. If you set only the "CTRL Q", so it works.
[2015-02-05 17:45:44]
This could be . Maybe it is used by something else on your system. Or the operating system is not allowing the Alt to be used.
Date Time Of Last Edit: 2015-02-05 17:46:01
[2020-08-06 19:17:27]
User209280 - Posts: 4
I seem to have a similar problem with the "Flatten All Positions" shortcut.
CTRL+C works fine on one computer but on the other computer none of the key combinations I have tried works.
What could be the issue?
[2020-08-06 19:32:02]
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
