Date/Time: Wed, 09 Sep 2026 16:44:30 +0000
[User Discussion] - AVAP alert code error
View Count: 1607
| [2015-01-21 09:31:44] |
| jivetrader - Posts: 410 |
according to http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html the following code should not produce an error (yet it does). please advise. AVAP[H][0] < AVAP[H -(.0001 * 1)][0] |
| [2015-01-21 10:04:50] |
The functionality does not yet support what the documentation indicates . We still need to work on that.
| [2015-01-21 10:10:58] |
in that case, how can i query the ask volume of the 2nd to highest price in the bar?
| [2015-01-21 17:30:58] |
Unless the actual price is specified, it is not possible to do right now.
| [2015-01-21 18:03:33] |
i believe these users are overlaying a study from a Numbers Bars chart. is it possible to query the bid/ask from the top 3 price levels of a bar using Numbers Bars or NB Calc Values?
| [2015-06-07 10:21:23] |
| User889191 - Posts: 61 |
Hello all BVAP[H - (TICKSIZE * 1)][0] and AVAP[H - (TICKSIZE * 1)][0] are still giving a Syntax error. When will this be fixed ? Software version: 1261 | 2015-06-07 10:22:22 Uses New Spreadsheets | 2015-06-07 10:22:22 Enabled for: Advanced Features. | 2015-06-07 10:22:22 Enabled for: Advanced Features 2. | 2015-06-07 10:22:22 Enabled for: Sierra Chart Historical Data Service. | 2015-06-07 10:22:22 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-06-07 10:22:22 Regards Roland |
